TwinTurbo.NET: Nissan 300ZX forum - Re: Are the crank sprocket guide washers installed correctly?
ltownsgrimreaper
on October 15, 2019 at 12:06 PM
Are the crank sprocket guide washers installed correctly? (n/m)
posted by jzack
on October 12, 2019 at 10:05 AM
I have the rear flat crank sprocket washer on and rotating it without the front on yet because I'm being to it shouldn't walk with that and the crank pulley off.
Need help with timing belt
ltownsgrimreaper
19:50:46 10/11/19
Re: Need help with timing belt
ltownsgrimreaper
19:52:24 10/11/19
jzack
10:05:53 10/12/19
Re: Are the crank sprocket guide washers installed correctly? -
ltownsgrimreaper
12:06:30 10/15/19
Where did you get your idler pulleys?
-Grimm-
11:27:14 10/14/19
Re: Where did you get your idler pulleys?
ltownsgrimreaper
12:11:34 10/15/19
